Hash: SHA1
| | Hi list, hi Ethan,
| | I finally started to upgrade my prod servers to 3.0.x (latest CVS for
| | now). Here are some bugs/odd things I came across:
| Oh well, one more thing. I use to set the service actionurl to
http://server/nagios/cgi-bin/extinfo.cg ... ERVICEDESC$
| (and something similar for hosts) and something magically replaced
| spaces in service names with + so that the url was working in text emails.
| This no longer works. Did it change (was it expected)? Is there any way
| to enable it back or I have to use an external script or html emails? It
| doesn't seem to be documented anywhere, not even in the what's new
section.
I ran with some debug output and there's something that catched my
attention. While processing SERVICEACTIONURL I noted this:
Cleaning options: global=3, local=4, effective=0
To understand this line we have to look at common/macros.c:209:
~ /* include any cleaning options passed back to us */
~ macro_options=(options & clean_options);
~ log_debug_info(DEBUGL_MACROS,2," Cleaning options: global=%d,
local=%d, effective=%d\n",options,clean_options,
I'm not totally sure it I get the logic here: should the effective flags
be global + local, or only flags that are in both global AND local?
If I get it right then line 209 should rather look like:
~ macro_options=(options | clean_options);
Which, ft I get the context right (this I'm not sure) would mean "apply
both the parent macro options and the current macro options" while
expanding macros that contain other macros.
On a side note, it looks like the sample config is missing some debug
values (DEBUGL_* defines). DEBUGL_MACROS is one of them (2048).
I'm also wondering if it would be possible to have something like this:
All custom macros starting with _STRIP_, _ESCAPE_ or _URL_ would be
stripped, escaped or url-encoded. That would be very useful, for example
in making custom URL macros. Possibly a Nagios 3.2 feature though...
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFIIcoz6dZ+Kt5BchYRApdbAJ9I85yHu3r7ImywrrMzILAyGUVauACg5AAo
QFZQn77qugSEL06+/CqtrMc=
=ByXo
-----END PGP SIGNATURE-----
