On May 3, 2008, at 11:13 AM, Anthony Montibello wrote:
> Recursive Has been around for years, I was using it on version 1.2
> currently I am using it with Nagios 3.0a1
Given that you used Recursive as a noun, is this an option that needs
to be enabled?
> I have the following line in my nagios.cfg
> cfg_dir=/usr/local/nagios/etc/servers
> in this directory I have up to 3 directories deep with some non cfg
> files as
> well as some empty directories and it is getting everything it should.
> Could the problem be Permissions not allowing the nagios user?
> or could the problem correlate to the verion of Linux/Unix you are
> running?
If it was permissions then it wouldn't read the subdirs just fine
when I specified them explicitly. And no, the directories are all 755.
I'm using FreeBSD 6.2-REL. There's nothing about FreeBSD that would
prevent recursion in subdirectories.
Jo Rhett
Net Consonance : consonant endings by net philanthropy, open source
and other randomness
