Joseph Hardeman wrote:
> Andreas,
> I have attached my diff.
I noticed. Two things though:
* When using the 'diff' program, you must name the oldest file (or
directory) first (as I typed it). You did the reverse. Please don't do
that again.
* When sending a patch out, it's considered common courtesy to keep it
as uncluttered as possible so you don't waste the time of those you're
asking for help by shipping a ton of junk. You can do that by reviewing
the patch-file in an editor before sending it out. If you had done that
this time you would have noticed that you need to run ./configure either
in both directories or in none. As it is now I'm not sure what you've
done in cgi/cgiutils.h (besides adding the SORT_ALIAS macro), and I have
no interest to reverse your patch and apply it to the same version of
the source that you created it from, meaning you've gotten less exact
help than I would otherwise have been willing to give.
> I modified the status.c and the cgiutils.h files,
> I am fairly sure I am missing something simple.
Yes you are. I'm afraid writing C-code isn't as simple as adding a
macro, however it's named. You also need to change the algorithm to
match on alias rather than hostname. This you can do by passing the
alias pointers from the host data structs to the strcmp() calls just
below where you replaced SORT_HOSTNAME with SORT_ALIAS.
> I am wanting any aliases
> that are capitalized to be at the top of the list and the non capitalized
> aliases below them. This will allow the help desk to see the primary
> servers and routers at the sites before seeing the access points. Will make
> it easier for them to see if a server or possibly circuit is down if the
> router is also down.
> I have done very limited c scripting. Mostly just looking though and
> modifying c programs before I compile them if they need to be. Most of its
> been with nagios over the years. Mostly I work in shell, perl or php.
Renaming variables, constants and macros isn't programming, whatever
language you choose.
OP5 AB www.op5.se
