Content-Type: multipart/alternative; boundary=00504502d312c3dbed047a0e71ec
--00504502d312c3dbed047a0e71ec
Content-Type: text/plain; charset=ISO-8859-1
My goal is clear : Keep the Nagios/Icinga compatibility with a
faster/modular implementation (and still fully open source of course).
Instead of offlist we can maybe go on in the icinga devel-list ?
Gab=E8s Jean
On Sat, Dec 5, 2009 at 3:14 AM, Michael Friedrich wrote:
> Hi,
> very interesting approach
> Maybe we can talk offlist and in private about your goals and maybe joini=
ng
> forces with Icinga. How about that?
> Kind regards,
> Michael
> nap wrote:
> Hi list,
> I would like to have your feed back about a (unfinished)
> reimplementation of Nagios named "Shinken" I wrote in Python that is
> faster and more modular than the current Nagios implementation in C
> (yes faster, you read correctly. I was the first surprised by that).
> =3D=3D The Shinken's history =3D=3D
> Few months, I start to work on a proof of concept for Nagios focus on
> distributed environments and performances. The main goal was to look
> for a distributed and high availability architecture. I was also
> thinking that Nagios' performances were quite good, but we can have
> more.
> For quick test and development, I used Python. I thought a process
> pool can make Nagios be quicker instead of forking a new process to
> kill it few seconds after for each checks. I also bypass the reaping
> way of Nagios : reading flat file is just too slow. Instead, the
> results are a structure that is send directly to the scheduler. No
> files, more performances. To be equal to Nagios, I add the same
> monitoring logic in the scheduler : HARD/SOFT states, dependencies
> (parents, servicedep, hostdep, etc) and database export (Merlin).
> Shinken used the standard Nagios conf file.
> And the perf are quite good : with a Nagios3, a small check (do a
> echo + exit) and a medium range server I run at 10000 checks in
> 5minutes (latency near 1s), 30K with full tweaks. With my tool, I run
> 150K !!
> =3D=3D The global architecture =3D=3D
> For the Architecture, I think we must use the Unix Way of doing things
> : one tool by usage. For now, Nagios do nearly every things : reads
> conf, schedule, launch checks and raise notifications. I try an
> architecture where the administrator can have any host/services he
> wants and the daemons are just resources to manage this. The
> architecture I propose is the following :
> *Arbiter : a daemon that read the configuration, cut it automatically
> (keep relations like parents in the same conf) in N confs, where N is
> the number of schedulers we have. It dispatchs the configuration and
> also read the orders in nagios.cmd and dispatch orders to schedulers.
> *Schedulers : do the scheduling by looking at states of
> hosts/services. It just do checks/notifications/event handlers queues
> for others daemons. Same things for event broker informations : it's
> just a queue.
> *pollers : use a processes Pool, get checks to launch in schedulers
> and returns results to schedulers.
> *reactionners : same than pollers, but for notifications and event handle=
rs.
> *brokers : get event broker informations from schedulers and "do
> things" why them (like create the service-perfdata file, or fill
> databases).
> The poller way of doing is like DNX, nothing new here. The
> reactionners allow the administrators to have a unique daemon to send
> all notifications of all his schedulers (usefull for SMTP
> authorizations or the fill of a unique RSS file with all
> notifications). The schedulers do not launch checks, so they do not
> get latency when they launch notifications or event handlers.
> The load balancing is automatic : the arbiter cuts the conf and
> dispatch thems. For the high availability : there can be spare daemons
> : if a daemon die, another take it's configuration (the Arbiter "ping"
> daemons, and if a daemon failed, it just sen
...[email truncated]...
