Hiren Patel wrote:
> Cary Petterborg wrote:
>> I have one question and one observation in addition to what I already
>> said....
>> Question:
>> In the case of the web server and nagios being on the same system, how
>> much is an fsync() really going affect the performance of the system?
>> Can someone "quantify" the impact of a single fsync? (I guess that is
>> technically a second question.) If it were to do a sync() (where all the
>> open files are checked to ensure that they are sync'd) instead of an
>> fsync(), I would definitely agree - much bigger impact. But, the single
>> fsync at the end of writing a file should not be of any real
>> significance, except in the case where it means that the data is
>> actually there where it should be if it *is* done (e.g. my case).
> I tried a program which I meant to attach to this mail that I deleted by
> mistake as I was composing this mail, that fopen'd a file, wrote a
> character at a time and either fclosed at the end, or fsync'd after each
> character, or sync'd after each character. it wrote 1MB worth of
> characters to the file.
Ahmm... That's not really such a great test, tbh. Try the write throughput
with a testing tool for it and then divide the size of the file to be
synced with the actual write speed of the disk and you'll get something
rather close to the cost of a single fsync call for a particular file.
> not sure how useful this really is to get an idea, but sync is clearly
> to be avoided as you mentioned. what do you guys make of the difference
> between fsync and no fsync in relation to nagios?
fsync() isn't needed when using a sane file system. When using an insane
one, there are no guarantees that fsync() works anyway, so why use it?
OP5 AB www.op5.se
on peace.
