------_=_NextPart_001_01C26897.C1C72C22
Content-Type: text/plain;
charset="us-ascii"
Greetings to all,
I've written this simple bash script for the check_procs plug-in to
invert the logic of the result.
This is an excerpt from the script source...
# Why I need this wrapper?
# This wrapper is useful to check for a missing process (like a Java
application or anything else)
# that must be running all the time. In this case you have to get a
CRITICAL status from the plug-in when the application
# is not running. This is the typical scenario.
# I preferred to make a wrapper to add the 'NOT' functionality to the
check_procs plug-in instead of modifying the source code.
# I've plenty of installations of plug-ins and I'm too lazy to recompile
them all. If the 'NOT' feature will be included in a
# future release of check_procs plug-in, this wrapper will be useless.=20
# ... but for now... enjoy it!
# To use this script you need the check_procs plug-in that is part of
nagios/netsaint plug-ins
# available from http://www.nagios.org/download/#plugins
# example 1 (with original check_procs plug-in):
# $ check_procs -c 0-0 -u root -a "someargument"=20
#=20
# This example gives a CRITICAL status when you have one or more
processes with "someargument" and OK
# status when there are no processes with "someargument"
# example 2 (with the plug-in wrapper):
# $ check_procs_not "-c 0-0 -u root -a "someargument""
# gives an OK status when you have one or more processes with
"someargument" and CRITICAL status when
# there are no processes with "someargument"=20
Hope to be of help...=20
xmedia
New Media Agency
Stefano Coletta mailto:[email protected]
Network Admin www.xmedia.net
Personal Site www.mindcreations.com
via Francesco Benaglia, 13 - Tel. +39 06 588851
00153 Rome Italy fax +39 06 58885016
Content-Type: application/octet-stream;
name="check_procs_not"
Content-Description: check_procs_not
filename="check_procs_not"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...[email truncated]...
