[Nagios-devel] Config.c Patch to check if temp_path is writeable
--------------000502000309060006090307
Content-Type: text/plain; charset=ISO-8859-15
Hi List,
again a small patch to config.c agains lates cvs code.
within the pre_flight_check this patch tries to write to the temp_path
directiv and sets an error if it wasn't able to write.
After successfull write I hope it's cleaning up properly.
Best regards,
Hendrik
Content-Type: text/x-patch;
name="config.c.patch"
Content-Disposition: inline;
filename="config.c.patch"
--- nagios3-clean/base/config.c 2007-04-11 19:00:55.000000000 +0200
+++ nagios3/base/config.c 2007-04-11 21:25:29.000000000 +0200
@@ -1940,6 +1940,22 @@
if(verify_config==TRUE)
printf("Checking misc settings...\n");
+ /* check if we can write to temp_path */
+ int temp_path_fp;
+ char *test_temp_path = NULL;
+ asprintf(&test_temp_path, "%s/nagiosXXXXXX", temp_path);
+ if ( (temp_path_fp=mkstemp(test_temp_path)) == -1 ) {
+ asprintf (&temp_buffer, "\tError while attempting to write to temp_path ('%s') - %s\n", temp_path, strerror(errno));
+ write_to_logs_and_console(temp_buffer,NSLOG_VERIFICATION_WARNING,TRUE);
+ errors++;
+ my_free((void **)&temp_buffer);
+ else {
+ close(temp_path_fp);
+ remove(test_temp_path);
/* warn if user didn't specify any illegal macro output chars */
if(illegal_output_chars==NULL){
asprintf(&temp_buffer,"%s","Warning: Nothing specified for illegal_macro_output_chars variable!\n");
--------------000502000309060006090307--
