--e89a8f2354bd63ce3604bf87bd6c
Content-Type: text/plain; charset=ISO-8859-1
Hi everybody,
I use Nagios, release 3.2.3, in a distributed environment, with a central
server and several colector servers.
For a long time I=B4m seeing errors on the passive check mechanism on the
central server, as we can see below.
Sometimes, on the central server, the states and number of attempts don=B4t
follow the correct order, going from SOFT2 to HARD4, for example. However,
on the colector server everything is OK.
Log from Central Server:
Host Up[2012-05-05 01:06:48] HOST ALERT: node;UP;HARD;1;TCP OK - 0.005
second response time on port 135
Host Down[2012-05-05 01:05:40] HOST ALERT: node;DOWN;HARD;4;CRITICAL -
Socket timeout after 10 seconds
Host Down[2012-05-05 01:04:16] HOST ALERT: node;DOWN;SOFT;2;CRITICAL -
Host Down[2012-05-05 01:02:55] HOST ALERT: node;DOWN;SOFT;1;CRITICAL -
Log from Colector Server:
Host Up[05-05-2012 01:06:31] HOST ALERT: node;UP;SOFT;4;TCP OK - 0.005
Host Down[05-05-2012 01:05:21] HOST ALERT: node;DOWN;SOFT;3;CRITICAL -
Host Down[05-05-2012 01:04:01] HOST ALERT: node;DOWN;SOFT;2;CRITICAL -
Host Down[05-05-2012 01:02:41] HOST ALERT: nodeDOWN;SOFT;1;CRITICAL -
Has anybody seen this kind of problem? Can someone help me?
Thanks.
Content-Type: text/html; charset=ISO-8859-1
Hi everybody,
=A0
I use Nagios, release 3.2.3, in a distributed environment, with a cent=
ral server and several colector servers.
=A0
For a long time I=B4m seeing errors on the passive check mechanism on =
the central server, as we can see below.
=A0
Sometimes, on the central server, the states=A0and number of attempts=
=A0don=B4t follow the correct order, going from SOFT2 to HARD4, for example=
. However, on the colector server everything is OK.
=A0
Host Up[2012-05-05 01:06:48] HOST ALERT: node;UP;HARD;1;TCP OK - 0.005=
Host Down[2012-05-05 01:05:40] HOST ALERT: node;DOWN;HARD;4;CRITICAL -=
Socket timeout after 10 secondsHost Down[2012-05-05 01:04:16] HOST ALE=
RT: node;DOWN;SOFT;2;CRITICAL - Socket timeout after 10 secondsHost Dow=
n[2012-05-05 01:02:55] HOST ALERT: node;DOWN;SOFT;1;CRITICAL - Socket timeo=
ut after 10 seconds
=A0
Host Up[05-05-2012 01:06:31] HOST ALERT: node;UP;SOFT;4;TCP OK - 0.005=
second response time on port 135Host Down[05-05-2012 01:05:21] HOST AL=
ERT: node;DOWN;SOFT;3;CRITICAL - Socket timeout after 10 secondsHost Do=
wn[05-05-2012 01:04:01] HOST ALERT: node;DOWN;SOFT;2;CRITICAL - Socket time=
Host Down[05-05-2012 01:02:41] HOST ALERT: nodeDOWN;SOFT;1;CRITICAL - Socke=
=A0
=A0
Thanks.
=A0
--e89a8f2354bd63ce3604bf87bd6c--
