Re: [Nagios-devel] 2 calls to unlink in checkresults
--------------050009040203040605060301
Content-Type: text/plain; charset=iso-8859-15; format=flowed
On 5/19/09 5:01 AM, Andreas Ericsson wrote:
>> Since process_check_result_queue() has already loaded all checkresult
>> files in a list in memory (by calling add_check_result_to_list() in
>> process_check_result_file()), reap_check_results() shouldn't call
>> delete_check_result_file() at all.
>> Does it make any sense to you?
> Yes, but it seems unnecessarily complex. I think I'll revamp it so
> it's read once and deleted immediately after.
Here is a patch against Nagios 3.0.6 fixing the problem.
delete_check_result_file() is now called from
process_check_result_file() only.
Feel free to comment and/or improve it.
Mathieu
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
name="fix_multiple_calls_to_delete_check_result_file.patch"
filename*0="fix_multiple_calls_to_delete_check_result_file.patch"
diff -Naur nagios-3.0.6.orig/base/checks.c nagios-3.0.6/base/checks.c
--- nagios-3.0.6.orig/base/checks.c 2009-05-19 12:48:13.000000000 -0400
+++ nagios-3.0.6/base/checks.c 2009-05-19 12:49:59.000000000 -0400
@@ -163,9 +163,6 @@
logit(NSLOG_RUNTIME_WARNING,TRUE,"Warning: Check result queue contained results for service '%s' on host '%s', but the service could not be found! Perhaps you forgot to define the service in your config files?\n",queued_check_result->service_description,queued_check_result->host_name);
- /* delete the file that contains the check results, as well as the ok-to-go file */
- delete_check_result_file(queued_check_result->output_file);
/* free memory */
free_check_result(queued_check_result);
my_free(queued_check_result);
@@ -188,9 +185,6 @@
/* make sure the host exists */
logit(NSLOG_RUNTIME_WARNING,TRUE,"Warning: Check result queue contained results for host '%s', but the host could not be found! Perhaps you forgot to define the host in your config files?\n",queued_check_result->host_name);
/* free memory */
@@ -206,12 +200,6 @@
handle_async_host_check_result_3x(temp_host,queued_check_result);
- /* files can contain multiple check results - in this case, the file will be removed when the first check result is processed */
- log_debug_info(DEBUGL_CHECKS|DEBUGL_IPC,1,"Deleted check result file '%s'\n",queued_check_result->output_file);
/* free allocated memory */
diff -Naur nagios-3.0.6.orig/base/utils.c nagios-3.0.6/base/utils.c
--- nagios-3.0.6.orig/base/utils.c 2009-05-19 13:05:14.000000000 -0400
+++ nagios-3.0.6/base/utils.c 2009-05-19 13:11:18.000000000 -0400
@@ -2485,6 +2485,8 @@
/* other (current) files are deleted later (when results are processed) */
delete_check_result_file(fname);
+ log_debug_info(DEBUGL_CHECKS|DEBUGL_IPC,1,"Deleted check result file '%s'\n",fname);
return OK;
--------------050009040203040605060301--
