Re: [Nagios-devel] RFC: Escalations Sets
Hi Ethan,
first of all, thanks for your feedback.
Ethan Galstad wrote:
> I agree that this could be a useful feature. You can't do this quite as
> easily as you suggest, but you can at least make use of templates to
> make shorter escalation definitions...
> # TEMPLATES
> define serviceescalation{
> name se1-template
> first_notification 6
> last_notification 9
> contact_groups somegroup
> register 0
> name se2-template
> first_notification 10
> last_notification 0
> contact_groups someothergroup
> register 0
> # ESCALATIONS
> use se1-template
> host_name somehost
> service_description someservice
> use se2-template
> host_name somehost
> You can also use hostgroup_name and servicegroup_name directives in
> escalation definitions and * wildcards for the service_description to
> simplify the config.
Yeah, i know that and use it to its max. ;-) A typical escalation looks
like this at the moment:
use esclevel1-17x5-sms
hostgroup_name foo_hosts
service_description Disk Space: /bar
use esclevel2-17x5-voice
use esclevel3-17x5-voice
Depending on how many escalation levels you have, the number of
escalations per service changes. So, at the moment, i have three
definitions per service nad hostgroup as a minimum. It would be nice to
be able to consolidate these settings to save a lot of copy and paste.
As a temporary solution, i build a script fetching all services for
hosts specified in a hosts-configfile and write the escalation files for
all services not found in a bypass file. But actually, i think this is
not the most elegant solution.
One more question: is it possible to negate specific services in an
escalation like i am able to negate host in hostgroups in Nagios 3?
Something like this:
service_description *, ! Disk Space: /bar
Regards,
Marcus
