--------------010206020506090906060403
Content-Type: text/plain; charset=ISO-8859-1
On 09/01/2010 01:54 PM, Ethan Galstad wrote:
> Please resubmit this patch against CVS HEAD, as your previous patch was=
=20
> already applied. Thanks!
Patch vs. cgi/config.c Rev 1.50 (HEAD as of now) attached.
Kind regards,
J. Bern
>> -- Replaced the offending strtok() with some local code ...
>> -- ... which also handles the backslash escapes of Nagios 3.x.
>> -- Tells "(undefined)" and "(empty)" $ARGn$s apart.
>> -- Warns of $ARGn$s with leading or trailing whitespace ...
>> -- ... and additionally puts them into "..." to make
>> sure that there'll be *something* displayed with the $ARGn$'s color
>> (see the "unused: $ARG5$=3D" line in the screenshot for an example)=
>> -- Changed a boatload of "printf(...,some_string);" to
>> "printf(...,html_encode(some_string,FALSE));".
>> The whitespace detection is still not quite finished because I hit a
>> snag in the existing code, namely, in cgi/cgiutils.c::url_encode() :
>>> /* spaces are pluses */
>>> else if((char)input[x]>> str[y]=3D'+';
>>> y++;
>>> /* anything else gets represented by its hex value */
>>> else{
>> Note the "> whenever a command contains whitespace *other* than spaces, the
>> hyperlink to config.cgi?type=3Dcommand&expand=3D... converts it to spa=
ces
>> (as seen in $ARG1$ in the screenshot; I currently have the code output
>> "[WS]" instead of "[SP]" whenever it sees spaces to obscure the proble=
m).
>> I would like to get and display the *original* whitespace characters (=
as
>> simulated, by manually changing the URL, for $ARG2$ and $ARG5$ in the
>> screenshot), but I don't feel comfortable changing the widely-used
>> url_encode() just like that ... any opinions?
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
name="nagios-3.2.1-CommandExpand-patch.Increment20100901.txt"
filename*0="nagios-3.2.1-CommandExpand-patch.Increment20100901.txt"
--- config.c.HEAD 2010-09-01 14:57:33.000000000 +0200
+++ config.c 2010-08-31 15:40:37.000000000 +0200
@@ -94,7 +94,6 @@
int display_type=DISPLAY_NONE;
char to_expand[MAX_COMMAND_BUFFER];
-char *command_args[MAX_COMMAND_ARGUMENTS];
char hashed_color[8];
int embedded=FALSE;
@@ -530,9 +529,9 @@
printf("\n",bg_class);
printf("%s\n",bg_class,
- url_encode(temp_host->name),CONFIG_CGI,url_encode(temp_host->name),temp_host->name);
- printf("%s\n",bg_class,temp_host->alias);
- printf("%s\n",bg_class,temp_host->address);
+ url_encode(temp_host->name),CONFIG_CGI,url_encode(temp_host->name),html_encode(temp_host->name,FALSE));
+ printf("%s\n",bg_class,html_encode(temp_host->alias,FALSE));
+ printf("%s\n",bg_class,html_encode(temp_host->address,FALSE));
printf("",bg_class);
for(temp_hostsmember=temp_host->parent_hosts;temp_hostsmember!=NULL;temp_hostsmember=temp_hostsmember->next){
@@ -540,7 +539,7 @@
if(temp_hostsmember!=temp_host->parent_hosts)
printf(", ");
- printf("%s\n",CONFIG_CGI,url_encode(temp_hostsmember->host_name),temp_hostsmember->host_name);
+ printf("<a href='%s?type=hosts&expand=%s'
...[email truncated]...
