--Apple-Mail-9-935396692
Content-Type: text/plain;
charset=US-ASCII;
format=flowed
I have compiled nagios-cvs (latest) on a redhat 9 box and am having
troubles with it starting. I first used my configs that I had been
using and had problems, so I put in the default nagios.cfg and
minimal.cfg and am having the same problem.
Configured wtih: ./configure --datadir="/usr/share/nagios"
--bindir="/usr/bin" --libexecdir="/usr/lib/nagios/plugins"
--localstatedir="/var/log/nagios" --sbindir="/usr/lib/nagios/cgi"
--sysconfdir="/etc/nagios" --with-cgiurl="/nagios/cgi-bin"
--with-command-user="apache" --with-command-grp="apache"
--with-gd-lib="/usr/lib/" --with-gd-inc="/usr/include/"
--with-init-dir="/etc/rc.d/init.d/" --with-htmurl="/nagios"
--with-lockfile="/var/run/nagios.pid" --with-mail="/bin/mail"
--with-nagios-user="nagios" --with-nagios-grp="nagios"
--enable-embedded-perl --with-perlcache --with-template-objects
--with-template-extinfo --enable-event-broker --enable-DEBUG0
--enable-DEBUGALL
make all
make install install-config install-init install-commandmode
The final debug lines are: (I attached full output)
find_service() start
find_service() end
write_to_all_logs() start
write_to_syslog() start
write_to_syslog() end
write_to_log() start
write_to_log() end
write_to_all_logs() end
Caught SIGSEGV, shutting down...
close_command_file() start
[root@master root]#
I am not sure what is telling it to quit. Where do I need to go from
here to figure it out?
jl
x-unix-mode=0644;
name="nagios.txt"
filename=nagios.txt
[root@master root]# /usr/bin/nagios /etc/nagios/nagios.cfg
Nagios 2.0a1
Copyright (c) 1999-2004 Ethan Galstad ([email protected])
Last Modified: 11-18-2003
License: GPL
reset_variables() start
init_macrox_names() start
init_macrox_names() end
reset_variables() end
read_main_config_file() start
Config file: /etc/nagios/nagios.cfg
Line 19 = 'log_file=/var/log/nagios/nagios.log'
log_file set to '/var/log/nagios/nagios.log'
Line 46 = 'cfg_file=/etc/nagios/minimal.cfg'
Line 78 = 'object_cache_file=/var/log/nagios/objects.cache'
Line 91 = 'resource_file=/etc/nagios/resource.cfg'
processing resource file '/etc/nagios/resource.cfg'
read_resource_file() start
write_to_logs_and_console() start
write_to_log() end
write_to_console() start
Error: Cannot open resource file '/etc/nagios/resource.cfg' for reading!
write_to_console() end
write_to_logs_and_console() end
Line 101 = 'status_file=/var/log/nagios/status.dat'
Line 109 = 'nagios_user=nagios'
nagios_user set to 'nagios'
Line 117 = 'nagios_group=nagios'
nagios_group set to 'nagios'
Line 129 = 'check_external_commands=0'
check_external_commands set to FALSE
Line 148 = 'command_check_interval=-1'
command_check_interval set to -1
Line 160 = 'command_file=/var/log/nagios/rw/nagios.cmd'
command_file set to '/var/log/nagios/rw/nagios.cmd'
Line 168 = 'comment_file=/var/log/nagios/comments.dat'
Line 176 = 'downtime_file=/var/log/nagios/downtime.dat'
Line 184 = 'lock_file=/var/run/nagios.pid'
lock_file set to '/var/run/nagios.pid'
Line 194 = 'temp_file=/var/log/nagios/nagios.tmp'
temp_file set to '/var/log/nagios/nagios.tmp'
Line 204 = 'event_broker_options=-1'
event_broker_options set to 8191
Line 233 = 'log_rotation_method=d'
log_rotation_method set to 2
Line 241 = 'log_archive_path=/var/log/nagios/archives'
log_archive_path set to '/var/log/nagios/archives'
Line 249 = 'use_syslog=1'
use_syslog set to TRUE
Line 257 = 'log_notifications=1'
log_notifications set to TRUE
Line 265 = 'log_service_retries=1'
log_service_retries set to TRUE
Line 273 = 'log_host_retries=1'
log_host_retries set to TRUE
Line 282 = 'log_event_handlers=1'
log_event_handlers set to TRUE
Line 294 = 'log_initial_states=0'
log_initial_states set to FALSE
Line 305 = 'log_external_comm
...[email truncated]...
