Re: [Nagios-devel] Segmentation fault when nebmodule returns with
Tobias Mucke wrote:
> Hi Nagios developers,
> I am writing a Nagios event broker module. Thanks for this nice API.
> If my nebmodule_init function does not return with OK, Nagios 3.0b7
> (and also earlier versions) segfault. I tried to locate the root cause
> and found function lt_dlclose line 321 in nebmods.c.
> result=lt_dlclose(mod->module_handle);
> I don't understand why it segfaults at this line. The NEB helloworld.o
> from Nagios source works fine, so this is a problem in my NEB.
> Any help greatly appreciated. Thanks for your advice.
Since it's not a problem with the helloworld module, it's impossible to
diagnose this error without looking at your code.
OP5 AB www.op5.se
