Is it possible to connect nagios xi to gns3?
elvinchia
Post by elvinchia »
Is it possible to connect nagios xi to gns3 to monitor the devices which set up in GNS 3? If so, please provide the guideline or tutorial to do so.
Thanks in advance.
rdedon
Re: Is it possible to connect nagios xi to gns3?
Post by rdedon »
I see you have a thread going on gns3 forums as well.
This would have to be configured in CentOS and not in Nagios XI
system-config-network
From there you would make the needed changes to the network adapter. Nagios XI should not have to be adjusted but you will have to update any bookmaks/links to reflect this new IP.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
