Hi again,
"hostgroup_name" works great with b2 but found a undesirable.
if the hostgroup you specify in a service doesnt exist you get the following
error on verify,
"Error: Could not find hostgroup ', ' specified in service
***> One or more problems was encountered while processing the config
files...
the HTML documentation on the main and host config files, as well as the
here is an example of the service that produced the above error.
# Service definition
hostgroup_name test,production,qa,dumbuser
service_description reboot
is_volatile 0
check_period 24x7
max_check_attempts 5
normal_check_interval 5
retry_check_interval 1
contact_groups Unix-page-alert
notification_interval 10
notification_period workhours
notification_options w,u,c,r
check_command check_reboot
where dumbuser doesn't exist as a host group. again this is protecting the
user against himself really, and you cant trap all the errors(and the message
is close enough to allow you to find your problem). but i thought you might
want to know. if the hostgroups does exist, the comma is valid. so if i were
to say "test,production,qa" in the above everything would be fine.(meaning:
yay!!!)
Also a difference i noticed between "Netsaint" and "Nagios" is that Netsaint
allowed multi-grouped hosts. where nagios doesn't this makes total sense if
you are using "hostgroup_name" for a service
and it appears that this is the only time it will spit out an error.
IE: Myserver exist in production and qa using the above example, you get a
"service already defined, for Myserver. wonder why this could be *smile*
this is not an issue with my configuration because i dont want multi-grouped
hosts. but other people might?
*realizes how would the programer determine which hostgroup takes precendence
over the other*
Ethan Galstad wrote:
> Hi Kenneth -
> This should be fixed in beta 2, which I will be releasing sometime
> tonight.
> On 23 May 2002 at 16:47, kray1 wrote:
> > Hi Ethan,
> > found a bug based on the undocumented (hostgroup_name)
> > being used in services.
> > whenever you try to use the variable, regardless of which file you put
> > it in, with respect to a "service" it produces the following result.
> > tfsndsu4: [root] /apps/nagios/bin> nagios -v /apps/nagios/etc/nagios.cfg
> > Nagios 1.0b1
> > Copyright (c) 1999-2002 Ethan Galstad ([email protected])
> > Last Modified: 05-10-2002
> > License: GPL
> > Reading configuration data...
> > Segmentation Fault(coredump)
> > here is the service in question,
> > define service{
> > use generic-service ; Name of service
> > template to use
> > hostgroup_name test
> > service_description reboote
> > is_volatile 0
> > check_period 24x7
> > tried it with tabs, tried it with spaces, if i change the
> > "hostgroup_name" to "host_name" and give it a defined host, it works
> > the "test" host group is defined.
> > if you can tell me where to find the coredump ill send that to you too..
> > Sincerly,
> > Kenneth Ray
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.or
...[email truncated]...
