On 11/19/2010 08:45 PM, Ethan Galstad wrote:
> On 11/19/2010 9:35 AM, eponymous alias wrote:
>>> The nagios indentation has been discussed
>>> quite a few times, and once upon a time we
>>> agreed that it would be nifty if we could
>>> use a style that's supported by a program
>>> so contributors can auto-format their
>>> code before submitting it upstream.
>>> Unless someone complains before monday
>>> I'll add a Makefile target to indent the sources,
>>> run it once and then commit the results, with
>>> a note added so that future contributors know
>>> what to do to make their code conform to
>>> the standard.
>> While I agree on the objective of consistent
>> formatting, I think the timing of this change
>> is all wrong. Patch contributors generally base
>> their changes on the last stable release, which
>> will remain with the old formatting. Thus patches
>> will need to be manually re-hacked for the new
>> format if you make this change now. Instead,
>> wait until immediately before the next stable
>> release, and make the change then, so everyone
>> starts with the same code base for further patches.
> Agreed. This change should wait.
> Code formatting should be fixed to be consistent with existing code
> *before* it is applied to CVS/SVN/etc. Otherwise you get into a world
> of hurt un-applying patches if necessary.
> There are several patches that have been applied with different styles
> lately. These should be fixed to match the current coding/indentation
> style until a mass change is made on everything.
> From that point on, all patches should be in the same format as the
> main codebase, or should be made to match by committers before being
> applied.
Sensible thinking. I'll add the 'indent' target to the Makefile so we
can run it before the next release then.
OP5 AB www.op5.se
on peace.
