Stephen Gran wrote:
> On Tue, Sep 21, 2010 at 12:22:36AM +0100, Stephen Gran said:
>> This is my simple minded attempt at matching the originally reported
>> failure case (host checks being skipped when service checks disabled).
>> It fails without my patch and passes with my patch. Hopefully it's
>> clear enough - please ask for clarification if not.
> Um, and now actually with the patch ...
A modified patch to base/events.c has been applied to CVS. The patch
fixes the "not able to disable service checks" problem, and retains the
effect of the original patch, which prevent incorrect variable cascading.
Give the latest CVS code a try and let me know if it fixes the problem.
If so, I'll cut a new release.
Ethan Galstad
Father of Nagios
___
Email: [email protected]|com
Web: www.nagios.com
