Re: [Nagios-devel] Nagios Core 3.4.4: crash on empty parents
A fix for that bug has now been committed to subversion on Sourceforge.
You could try the before and after version.
I'm planning to create a 3.4.5 release candidate tarball shortly, so you
could wait and download that as well.
On 2/22/13 12:53 PM, Paul Dubuc wrote:
> Could your config change have involved removal of a service that happened to
> be running at the time? I recently found this problem in 3.4.4 and can easily
> reproduce it.
> http://tracker.nagios.org/view.php?id=424
> Jens Hektor wrote:
>> Hi,
>> in the meantime I realized, that it is not so easy.
>> What happened was this:
>> in our 5k hosts / 11k services installation of nagios the accesspoints
>> get updated by a script that pulls data from a database and writes individual
>> files for each AP.
>> A colleague ran this script and forcing nagios to relaod nagios crashed.
>> I was not able to start nagios in that configuration and unfortunately
>> I could not take a core dump.
>> I suspected a memory error at that point and rebooted the machine but
>> the error persisted.
>> Running a diff against the old config files showed the missing parent
>> as only major difference. Correcting that manually in the file for that
>> AP fixed my problem.
>> Then I wrote the message to this list.
>> My colleague later showed me that there were other APs that had
>> missing parents so it became clear that it is not so simple to
>> reproduce the error.
>> At the moment I am stuck and I cannot tip the finger at the error, sorry.
>> So I will try later today if I can force nagios into that error again,
>> but as I think that nagios is pretty rocksolid I fear I am not able
>> to reproduce this.
>> So I will come back when I have found something and we can close this upto now.
>> Sorry and best regards, Jens Hektor
>> On 22.02.2013 02:59, Eric Stanley wrote:
>>> Jens,
>>> I just tried what you suggested to reproduce the issue, but it did not
>>> crash on me. Could you send what you used to get it to crash?
>>> Thanks,
>>> Eric
>>> On 2/17/13 10:27 PM, Jens Hektor wrote:
>>>> I had nagios core 3.4.4 crashing on an empty "parents" line in a host config.
>>>> Guess it should be easy to reproduce: simply add a line, where after the
>>>> "parents" are just some space characters.
>> Everyone hates slow websites. So do we.
>> Make your web apps faster with AppDynamics
>> Download AppDynamics Lite for free today:
>> http://p.sf.net/sfu/appdyn_d2d_feb
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
> [email protected]
Eric Stanley
___
Developer
Nagios Enterprises, LLC
Email: [email protected]
Web: www.nagios.com
