> > It seems to me that a {HOST,SERVICE}_STATUS event would only be fired
> > after the check had happened, so that would imply that this would always
> > be true if it was what you think it is. But that wouldn't make for a
> > useful datapoint, so I think we are both confused.
> I think Nagios just dumps all the data in the object struct to whatever
> is listening in the receiving end and doesn't differ between if the data
> passing takes place as the result of a timed event or as the result of
> some sort of state change. I know modules can schedule data to be passed
> at regular intervals as well as on events, so I guess that must be the
> answer.
Yes, but that still means that STATUS messages are still generated after a
check, right?
> > I don't understand.... but that's ok, I understand enough to know that I
> > can ignore this for now.
> > and reports.
> I'm really interested in having a look at what you've done. Perhaps I
> can improve it somehow and we could both benefit from it. Is it GPL'd or
> do you have some proprietary copyright on it?
Well, I have almost nothing yet except for a budding schema, a rough plan,
and the go-ahead from my managers.
more than happy to share the love. I would be estatic if I could get the
code included in contrib/
