Global Change To Services
Ben.Patrick
Post by Ben.Patrick »
Is there an easy way to change multiple services rather than going in to each one at a time? For example, to change the time between checks or command line switches.
Regards
Ben
tonyyarusso
Re: Global Change To Services
Post by tonyyarusso »
Ideally you should set things up to use templates, and then you can just change the template. It is also possible to do some things by writing your own SQL queries, but the former is the easy way.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
