On 03/28/2012 06:44 PM, Jim Winkle wrote:
> I'd like to set up Nagios contact_groups in the following way (but it's=
not
> working as expected):
> 1) In general, contact_groups for a host are notified about problems wi=
th the
> host and any service on the host.
> 2) Occasionally, we'd like other contact_groups to be notified about pr=
oblems
> with certain services on the host.
>=20
> If I'm understanding the documentation at
> http://nagios.sourceforge.net/docs/nagi ... itance.ht=
ml
> correctly (I'm running (3.3.1), it indicates that #1 can be done using =
implied
> inheritance and #2 by using additive inheritance, but it's not working =
as
> expected.
I tried that myself a while back, and dug into the (3.2.x) code when it
didn't work for me, either. (I'll assume that the relevant code is still
the same in 3.3.1.) The fact of the matter is that in
xdata/xodtemplate.c:xodtemplate_read_config_data(), you have calls - in
this order - to
1. xodtemplate_resolve_objects(), which calls
xodtemplate_resolve_service() on all service objects, which applies
all templates, using xodtemplate_get_inherited_string() *IFF* both
service and template have the corresponding config setting, which
does the additive inheritance,
2. xodtemplate_clean_additive_strings(), which silently removes any
surviving "+" from contacts and contact groups settings of all
objects except host and service escalations, and
3. xodtemplate_inherit_object_properties(), which does the host-to-
service inheritance.
They're not sitting *next* to each other, though - in particular, most
of the "recombombulation" stuff intervenes between 2. and 3. - and
turning things around would introduce a behavioral change for identical
configs (=3D bad), anyway, so I never even tried to write a patch.
Regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
