Problem installing NagiosXI
emtouceda
Post by emtouceda »
Hello
I am installing nagiosxi on a Centos 5.5 64bits, and i configured a proxy to use yum and wgetrc with the exception no_proxy=localhost,127.0.0.0/8 and http_proxy=http://ip:port/ and i have this error on step E, the error is:
ERROR: NagiosQL import appears to have failed - exiting. (Reason: Nagios Core configuration is invalid)
Can you help me?.
thanks
mguthrie
Re: Problem installing NagiosXI
Post by mguthrie »
You may have checked this already, but if not look through the suggestions on our FAQ for proxy configurations.
http://support.nagios.com/wiki/index.ph ... th_Proxies
