Re: [Nagios-devel] [PATCH] Fix memory corruption caused by a
Michael Marineau wrote:
> Greetings,
> The function unescape_newlines in cgi/cgiutils.c will blindly unescape
> any character preceded by the backslash by taking the value of the next
> character and incrementing to skip over it. This happens even when that
> next character is the terminating null, causing the loop to continue on
> corrupting memory until it hits another null character. The attached
> patch should fix this issue. It is against 3.0.6 but should still apply
> to the latest code.
> This bug is triggered when any plugin's output ends with a backslash
> which has been reported at least a couple times, most recently here:
> http://thread.gmane.org/gmane.network.n ... focus=6117
> Cheers,
Thanks Michael - fix is in CVS.
- Ethan Galstad
