Re: [Nagios-devel] Nagios 3.0 hanging (10/23 CVS)
Andreas Ericsson wrote:
> Shad L. Lords wrote:
>>>> Valgrind should be able to give a few hints. If you've got time to
>>>> run Nagios
>>>> under it on your system, it would most likely be very valuable.
>>> Not sure how to do this but I've got the time and willingness to
>>> learn. Just point me at some documentation and I'll plug away at it.
>>> I've done a little googling and have run the program with this for
>>> tonight:
>>> valgrind --leak-check=yes --time-stamp=yes
>>> --log-file=/tmp/trace/nagios-valgrind nagios /etc/nagios/nagios.cfg
>>> I'll make the results available tomorrow. If you would like other
>>> options please let me know which ones.
>> Well that didn't take nearly as long to fail as previous attempts. I've
>> attached both the nagios.log and the valgrind save. Let me know if
>> there is anything else you need.
> I've only browsed it briefly for now, but it looks as if some insignificant
> leaks are happning when reading the config (one-time hit though, so not
> very important). The macro releasing code seems to leak a bit too. That might
> be sorted by the recent CVS commit. Other than that, the embedded perl
> interpreter seems by far the most prominent leak.
> In total, Nagios leaks about 0.8MiB / second on your system when valgrind is
> running. Quite astonishing, really. Try without embedded perl. It should plug
> the worst leak, and the rest shouldn't be enough for you to notice between
> restarts.
One other thought as well - If you set "use_large_installation_tweaks"
to 1, set it back to zero. When enabled, this option will make child
processes (i.e. host/service checks) not free memory before they exit.
The Linux kernel frees this memory if not done explicity/properly by the
code, and its more efficient at doing it. However, the BSD kernel may
act a bit differently and not free memory, which could cause a memory leak.
Just another option to try out.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
