RE: [Nagios-devel] Fix: login as new user
Very nice! Works like a charm. :)
jc
> -----Original Message-----
> From: Robert [mailto:[email protected]]
> Sent: Friday, February 14, 2003 10:22 AM
> To: Carroll, Jim P [Contractor]
> Cc: [email protected]
> Subject: Re: [Nagios-devel] Fix: login as new user
> On Wed, Feb 12, 2003 at 15:45:04 -0600, Carroll, Jim P
> [Contractor] wrote:
> > Nope, no joy.
> I noticed some other browsers having problems, so I took
> another approach.
> This time no cookies, but a db-file on the server identifying
> a session by
> REMOTE_IP and HTTP_USER_AGENT. The required modules are in
> the standard
> Perl distribution. Does it work for you?
> Robert
> #!/usr/bin/perl -w
> use strict;
> use Fcntl;
> use DB_File;
> my $realm = "Nagios Access"; # Should be the same as
> in .htaccess
> my $dbfile = "/usr/local/nagios/var/rw/authcache.db";
> my $browser = $ENV{'HTTP_USER_AGENT'} || "Unknown browser";
> my $ip = $ENV{'REMOTE_ADDR'} || "Unknown IP";
> my $user = $ENV{'REMOTE_USER'} or &print_auth_ok;
> my $db = tie my %db, 'DB_File', $dbfile, O_CREAT|O_RDWR, 0640
> or &print_error;
> my $id = "$ip - $browser";
> if (my $lastuser = db_get($id)) {
> if ($user eq $lastuser) {
> &print_auth_required;
> } else {
> db_del($id);
> &print_auth_ok;
> } else {
> db_put($id, $user);
> &print_auth_ok;
> sub print_auth_required {
> print "Content-type: http/send-as-is\n";
> print "Status: 401 Authorization Required\n";
> print "WWW-Authenticate: Basic realm=\"$realm\"\n";
> print "Content-type: text/html\n";
> print "\n";
> print "Authorization is required\n";
> exit 0;
> sub print_auth_ok {
> print "Expires: now\n";
> print "\n";
> if (defined $user) {
> print "You are now logged in as $user\n";
> print "Click again if you want to login as another user.\n";
> } else {
> print "No authentication required\n";
> exit 0;
> sub print_error {
> print "\n";
> print "Internal error\n";
> exit 0;
> sub db_get {
> my ($key) = @_;
> my $val;
> $db->get($key, $val) == 1 ? return undef : return $val;
> sub db_put {
> my ($key, $val) = @_;
> $db->put($key, $val);
> $db->sync();
> return 1;
> sub db_del {
> my ($key) = @_;
> $db->del($key);
> $db->sync();
> return 1;
