[PATCH] fix tests compile in t-tap/
--------------030107070108000307060408
just figured that current svn/git head does not compile within t-tap/,
attached git patch resolves that.
test_checks segfaults for various reasons i've not yet debugged.
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
mobile: +43 664 60277 14359
fax: +43 1 4277 14338
web: http://www.univie.ac.at/zid
http://www.aco.net
Lead Icinga Core Developer
http://www.icinga.org
Content-Type: text/x-diff;
name="0001-fix-tests-compile-in-t-tap.patch"
filename="0001-fix-tests-compile-in-t-tap.patch"
From 9e327876b936e3965de3d3ee081a7c3210cad105 Mon Sep 17 00:00:00 2001
Date: Mon, 13 Feb 2012 18:27:06 +0100
Subject: [PATCH] fix tests compile in t-tap/
recent last_program_stop was not provided
within stubs and therefore failing on make
of t-tap
t-tap/test-stubs.c | 1 +
t-tap/test_nagios_config.c | 1 +
2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/t-tap/test-stubs.c b/t-tap/test-stubs.c
index 3f374b9..8d8522f 100644
--- a/t-tap/test-stubs.c
+++ b/t-tap/test-stubs.c
@@ -108,6 +108,7 @@ unsigned long syslog_options;
int verify_config;
int test_scheduling;
time_t last_log_rotation;
+time_t last_program_stop;
int log_rotation_method;
int daemon_mode = TRUE;
char *debug_file = "";
diff --git a/t-tap/test_nagios_config.c b/t-tap/test_nagios_config.c
index 9ea9773..b4514a7 100644
--- a/t-tap/test_nagios_config.c
+++ b/t-tap/test_nagios_config.c
@@ -132,6 +132,7 @@ char *new_program_version = NULL;
time_t last_command_check = 0L;
time_t last_command_status_update = 0L;
time_t last_log_rotation = 0L;
+time_t last_program_stop = 0L;
int use_aggressive_host_checking = DEFAULT_AGGRESSIVE_HOST_CHECKING;
unsigned long cached_host_check_horizon = DEFAULT_CACHED_HOST_CHECK_HORIZON;
1.7.9
--------------030107070108000307060408--
