--------------040307070004040807080606
Good point. How does the attached patch look for fixing this? I may
have to release the patch standalone for a few days, as the SourceForge
CVS servers are currently offline (!).
sean finney wrote:
> hey ethan,
> On Thu, May 11, 2006 at 02:17:14PM -0500, Ethan Galstad wrote:
>> If the packet is greater than INT_MAX in size, then yes, the integer
>> would probably overflow and result in a negative size. The patch to the
>> Nagios CGI handles negative values for the Content-Length, so unless I'm
>> missing something, we should be okay. Someone please chime in if you
>> believe otherwise.
> try setting Content-Length to INT_MAX-1. because later:
> if(!(cgiinput=(char *)malloc(content_length+1))){
> sean
Ethan Galstad,
Nagios Developer
Email: [email protected]
name="getcgi.patch"
Content-Disposition: inline;
filename="getcgi.patch"
*** cgi/getcgi.c 2006-05-12 17:18:52.000000000 -0500
--- ../../nagios-releases/nagios-2.3/cgi/getcgi.c 2006-04-12 14:17:23.000000000 -0500
*** 2,8 ****
* GETCGI.C - Nagios CGI Input Routines
! * Last Modified: 05-12-2006
--- 2,8 ----
! * Last Modified: 04-12-2006
*** 169,175 ****
printf("getcgivars(): No Content-Length was sent with the POST request.\n") ;
exit(1);
! if(content_length=(INT_MAX-1))
content_length=0;
printf("getcgivars(): Could not allocate memory for CGI input.\n");
--- 169,175 ----
exit(1);
! if(content_length<0)
content_length=0;
--------------040307070004040807080606--
