Re: [Nagios-devel] check_nrpe parses arguments to -a (with fix)
John Sellens wrote:
> check_nrpe parses arguments to the -a option, which it
> shouldn't, since those args are for the remote plugin,
> not for check_nrpe itself.
> Repeat by:
> /usr/local/libexec/nagios/check_nrpe -H one -c hello -a there -V
> which will likely complain about -V being invalid.
> I ran into this when I was trying to do an indirect check_http:
> check_nrpe -H gatehost -c check_http -H webhost
> and noticed that check_nrpe was trying to connect to webhost
> and not gatehost.
> Here's a quick diff to src/check_nrpe.c that stops parsing args
> once it finds -a, and also adds the -V option to the getopt args.
> Thanks - cheers!
> John
You can avoid this problem by quoting any arguments passed with the -a
option:
./check_nrpe -H one -c hello -a "opt1 -V opt2 -xyz opt3"
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
