[Nagios-devel] [PATCH] Fix to allow incomplete service dependency
--------------040906030505080106070805
The attached patch fixes a problem with parsing service dependency
templates that specify "hostgroups" without "dependent_hostgroups" or
vice versa. The following config snippet triggers the bug:
define host {
use generic-host ; generic host template omitted for brevity
host_name b
define hostgroup {
hostgroup_name test-hg
alias test-hg
members a,b
define servicedependency {
register 0
name base-sd
hostgroups test-hg
Since it's not a registered object, the servicedependency template should be
valid, but Nagios reports "Could not expand dependent hostgroups and/or
hosts
specified in service dependency" instead.
This patch applies to both Nagios 2.5 and 2.6.
Jason Hoos
name="nagios-2.5-partial-deps-fix.diff"
Content-Disposition: inline;
filename="nagios-2.5-partial-deps-fix.diff"
The attached patch fixes a problem with parsing service dependency templates that specify "hostgroups" without "dependent_hostgroups" or vice versa. The following config snippet triggers the bug:
define host {
use generic-host
host_name b
define hostgroup {
members a,b
register 0
name base-sd
hostgroups test-hg
Since it's a template and not a full object, the servicedependency should be
valid, but Nagios reports "Could not expand dependent hostgroups and/or hosts
*** nagios-2.5/xdata/xodtemplate.c.orig Wed Oct 11 23:13:45 2006
--- nagios-2.5/xdata/xodtemplate.c Wed Oct 11 23:17:23 2006
*** 4060,4066 ****
for(temp_hostdependency=xodtemplate_hostdependency_list;temp_hostdependency!=NULL;temp_hostdependency=temp_hostdependency->next){
/* skip host dependencies without enough data */
! if(temp_hostdependency->hostgroup_name==NULL && temp_hostdependency->dependent_hostgroup_name==NULL && temp_hostdependency->host_name==NULL && temp_hostdependency->dependent_host_name==NULL)
continue;
/* get list of master host names */
--- 4060,4066 ----
! if((temp_hostdependency->hostgroup_name==NULL && temp_hostdependency->host_name==NULL) || (temp_hostdependency->dependent_hostgroup_name==NULL && temp_hostdependency->dependent_host_name==NULL))
continue;
*** 4119,4125 ****
for(temp_servicedependency=xodtemplate_servicedependency_list;temp_servicedependency!=NULL;temp_servicedependency=temp_servicedependency->next){
/* skip service dependencies without enough data */
! if(temp_servicedependency->hostgroup_name==NULL && temp_servicedependency->dependent_hostgroup_name==NULL && temp_servicedependency->host_name==NULL && temp_servicedependency->dependent_host_name==NULL)
continue;
--- 4119,4125 ----
! if((temp_servicedependency->hostgroup_name==NULL && temp_servicedependency->host_name==NULL) || (temp_servicedependency->dependent_hostgroup_name==NULL && temp_servicedependency->dependent_host_name==NULL))
continue;
--------------040906030505080106070805--
