Hash: SHA1
Am 28.09.09 20:26, schrieb Jose Luis Martinez:
> Hi,
> Currently I'm testing injecting big results into Nagios via a new
> program called nrd (Nagios Result Distributor) (I posted a while ago on
> this list, announcing it as nsca2).
> Currently I'm getting the results into Nagios fine, but ndo seems to
> have a bad time with big perfdata... The Nagios screens show all the
> perfdata correctly, but the results don't appear in the NDO db.
Since you are using b7 - yes.
The DB scheme is/was a 255 wide varchar.
Did you try to increase it like this:
ALTER TABLE `nagios`.`nagios_hostchecks` MODIFY COLUMN `perfdata`
VARCHAR(8192) NULL;
ALTER TABLE `nagios`.`nagios_hoststatus` MODIFY COLUMN `perfdata`
VARCHAR(8192) NULL;
ALTER TABLE `nagios`.`nagios_servicechecks` MODIFY COLUMN `perfdata`
VARCHAR(8192) NULL;
ALTER TABLE `nagios`.`nagios_servicestatus` MODIFY COLUMN `perfdata`
VARCHAR(8192) NULL;
> I activate debugging in NDO, and never see an INSERT with lots of
> perfdata. I've tracked down the problem to the following:
> - the ndo.dat file seems to get the data messed up:
> - reading through the code, it looks like every entry in the ndo.dat
> would finish in 999 (NDO_API_ENDDATA)
> - the perfdata entry 99 (NDO_API_PERFDATA) for "206:" seems to have a
> mix of data in it (starts like result "213", until you get another
> NDO_API_PERFDATA section, and at the end of the line you get a 999 (with
> no "\n" before it).
> - I attach a test.dat file that is a capture of the ndo.dat file so
> you can examine it.
> - I attach the script that is causing this: check_big_perfdata.pl
> I would expect to see the 500 perfdata entries that the big_perfdata
> check generates (as the Nagios status screens show them without problems)
> Looking around in the code, to find a possible cause, I think I found a
> small bug in io.c, also
> ndo_unescape_buffer:
> if (buffer[x+1]=='\t'){
> i think should be
> if (buffer[x+1]=='t'){
> but I think this is unrelated to the big perfdata problem.
> Any thoughs on why NDO is "eating up" the perfdata?
May be some buffer length restrictions in ndomod...
You give everything a developer wants to have to track down this
problem. Nice work!
I marked your mail and will go deeper into it. Would you please open a
tracker for it (http://tracker.nagios.org), feel free to assign it
directly to me (hbaecker).
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (Darwin)
iEYEARECAAYFAkrBIdcACgkQlI0PwfxLQjmz0QCePBC/XVDxZNSN2dUrxNr6Bz1S
zagAnj6dDQnEcJZpeyFlUVDcBlX/n021
=Oj2j
-----END PGP SIGNATURE-----
