[Nagios-devel] Hostgroup Definitions using Wildcards??
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C273C1.A0D34D40
Content-Type: text/plain
I am wondering if there is a way to use wild cards when specifying members
of a hostgroup? I know that I can use an * to select all hosts but I would
like to do something like router* or firewall* That way I can
define all my routers or firewalls with those prefixes and easily add them
to hostgroups.
Is this possible?
I already asked on the Users list and no one had an answer.
Kevin Miller
Sr. Network Security Engineer
Inflow Inc.
www.inflow.com
Work: 303-942-2934
Mobile: 303-548-1760
Content-Type: text/html
Clean
Clean
DocumentEmail
MicrosoftInternetExplorer4
st1\:*{behavior:url(#default#ieooui) }
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
<p class=3DMso
...[email truncated]...
