Re: [Nagios-devel] PHP user interface for Nagios
Hi, John:
El Lunes, 2 de Junio de 2003 23:23, John Arley Burns escribi=F3:
> This is good. I'm using Nagios in a context where I need form-based
> authentication. It would also be helpful if you could have screens to
> "edit config" as well as view it.
The "view config" option is merely a wrapper around the config.cgi CGI, sin=
ce=20
that was my very first idea: if I can just drop in a few PHP classes so I=20
have the same functionality current Nagios ui has, then I can go at my own=
=20
pace adding functionality or rewriting CGIs as I feel I can, and still usin=
g=20
the byproduct on a day by day basis.
As you can see what you propose is not a technical nigthmare, still it need=
s a=20
config access abstraction, which is not trivial (since that config can be=20
found into flat files, databases or, potentially any remote access procedur=
e)=20
and the "high level" access interface, so it seems not a few hours task. =20
Anyway I want a graphic configuration tool too, one that does respect any=20
by-hand change I'd do, comments and the like, so there's high chance I'll g=
o=20
for it.
On the other hand, you know this is open source: how could you help with th=
is?
=2D-=20
SALUD,
Jes=FAs
[email protected]
