Re: [Nagios-devel] [Nagios-users] Questions about Nagios quick
--=_4fb1627b4aacd642fa36a44cebc9326d
Content-Type: text/plain; charset=UTF-8;
format=flowed
Am 2013-03-01 09:05, schrieb Andreas Ericsson:
> On 02/28/2013 10:49 PM, Jonas Meurer wrote:
>> Am 20.02.2013 16:13, schrieb Jonas Meurer:
>>> Hello,
>> Hey again,
>>> we're using Nagios as monitoring system for several hundred systems.
>>> While navigating through hosts and services, recently two questions
>>> regarding the quick search (in navigation bar) raised:
>>> 1/ Why doesn't nagios search for host aliases as well? Is it possible
>>> to enable alias searching? We're using rather short values for
>>> host_name, and tend to add information like server position to the
>>> alias. Thus searching for host_name and alias would be awesome for
>>> us.
> Today it's not possible to enable alias searching. Patches welcome.
> If you create one, please use some format that makes it possible to add
> searching on other fields as well, such as "alias~" or some
> such.
>>> 2/ When searching for IP addresses, only the first match is returned.
>>> In some cases (e.g. NRPE Port forwarding through firewall), several
>>> hosts have the same IP address. For these cases it's rather
>>> irritating,
>>> that only the first matching host is returned.
> Tru dat. Patches welcome. You'll want to find and remove the correct
> "break" statement, I guess. Other than that it shouldn't be much
> trouble.
I finally managed to prepare a patch that fixes both shortcomings. It
adds
two new configuration options to configure the behavior of the
navigation
bar search: search for hostname only, or also for addresses, or also for
aliases.
I reported the patch as feature request at
http://tracker.nagios.org/view.php?id=459
Kind regards,
jonas
Content-Type: text/x-diff;
name=navbar-search.patch
filename=navbar-search.patch;
size=3898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...[email truncated]...
