I've noticed that using your example NEB module, occasionally there are
duplicate HOST_STATUS events. Maybe identical events are supposed to be
generated by the event broker and dispatched at the same time, but I don't
know why that would be. Has anybody else seen this, and is it a bug?
On Wed, 13 Oct 2004, Titus Anderson wrote:
> > So I'm looking into how to turn event broker events into SQL statements,
> > and I have some questions about the following fields found in both
> > HOST_STATUS and SERVICE_STATUS events. I'm hoping somebody else has
> > already digested the code and can clear up my confusion.
> > modified_attributes appears to be redundant, because there are other
> > fields for the flags it is used to carry (active_checks_enabled,
> > notifications_enabled, etc.). Or maybe it's that those other fields are
> > redundant? Or maybe I'm just missing something?
> Well, this part is easy to answer, just glancing through the code. It appears
> that the flags are set (but never cleared) whenever an external command alters
> a field of a host or service. For example, when you execute a
> CHANGE_NORMAL_HOST_CHECK_INTERVAL command via the external commands file, the
> MODATTR_NORMAL_CHECK_INTERVAL flag is set in the modified_attributes field for
> that host.
> The rest is somewhat guesses, but here goes:
> > When are these filled out, and with what?
> > event_handler - the event handler for this host or service; set at startup
> > performance_data - most recent performance data from a check; set with each
> check
> > problem_has_been_acknowledged - true or false; set if a problem has been
> acknowledged; I presume it is cleared when the problem goes away
> > acknowledgement_type - either ACKNOWLEDGEMENT_STICKY or
> ACKNOWLEDGEMENT_NORMAL; also set when the problem is acknowledged; don't know
> what the default value is, though
> No ideas on the rest. Haven't dug that deep yet.
> > What is the logic behind these values?
> > has_been_checked
> > should_be_scheduled
> > current_notification_number
> > What are these good for?
> > failure_prediction_enabled
> > percent_state_change
> > scheduled_downtime_depth
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
> This SF.net email is sponsored by: IT Product Guide on ITManagersJournal
> Use IT products in your business? Tell us what you think of them. Give us
> Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more
> http://productguide.itmanagersjournal.c ... promo.tmpl
> Nagios-devel mailing list
> [email protected]
