Re: [Nagios-devel] Fatal install problem in nagios-2.0b6
Thanks - A patch will be in CVS shortly.
On 1 Dec 2005 at 10:53, Rouven Homann wrote:
> Hi,
> just wanted to let you know, that the compile process with embedded perl
> enabled is broken with the new b6. 'configure' works fine without
> errors, but 'make all' gives many errors, such as the following snippet:
> gcc -g -O2 -D_REENTRANT -D_GNU_SOURCE -DTHREADS_HAVE_PIDS
> -fno-strict-aliasing -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
> -I/usr/lib/perl5/5.8.3/i586-linux-thread-multi/CORE -DHAVE_CONFIG_H
> -DNSCORE -c -o broker.o broker.c
> In file included from broker.c:26:
> ../include/common.h:31:1: warning: "_REENTRANT" redefined
> :4:1: warning: this is the location of the previous
> definition
> -DNSCORE -c -o nebmods.o nebmods.c
> In file included from nebmods.c:26:
> This problem was testet and confirmed on SuSE Linux 9.1 with perl 5.8.3
> and with Debian Sarge perl 5.8.4.
> regards
> Rouven Homann
> cimt AG
> Burchardstr. 17
> 20095 Hamburg
> Tel.: +49.40.53302-0 Fax: -22
> email: [email protected]
> http://www.cimt-ag.de
> This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
> for problems? Stop! Download the new AJAX search engine that makes
> searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
> http://ads.osdn.com/?ad_idv37&alloc_id 865&opick
> Nagios-devel mailing list
> [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
