Re: [Nagios-devel] [PATCH] Fix default value for
Hi Andreas,
On 14 Jan 2013, at 10:08, Andreas Ericsson wrote:
> On 01/14/2013 10:30 AM, Ton Voon wrote:
>> What I can't work out is how to set the env property in "define =
command". Can you provide some pointers and assistance?
>>=20
> Using a secondary list of key/value vectors. Since commands are =
usually
> fewer than 500 and remain pretty static, I'd just use a command->id
> indexed pointer-to-pointer list of key value vectors.
I couldn't work out how to create this array. I modelled it on =
command_ary, but it kept segfaulting when setting this first array =
element. I'm sure there's a malloc required somewhere, but I couldn't =
see how command_ary was being initialised. In the end, I've extended the =
command object to include an env attribute.
The next problem is that with an arbitrary list of environment =
variables, I need to pass this to the worker job creator. I can't see =
how to extend the wproc_* jobs, but it looks like the nagios_macros are =
not used. So I propose that we change:
static int wproc_run_job(worker_job *job, nagios_macros *mac)
to
static int wproc_run_job(worker_job *job, char **env)
Is this acceptable?
Ton
