Nagios/Centreon
brownie
Nagios/Centreon
Post by brownie »
Hi all
I have a problem...
I've downloaded some plugins from the exchange site of nagios to test some files in folders (e.g. if a file is older than 15 minutes i need to get a notification, a critical).
the situation is like this:
the remote server where i need to test on is a windows platform (with no Nagios installed on, i geuss) and the server where Nagios is installed on (also Centreon) is a Linux server.
So when i do some tests to search for folders and check if it's too old or not, it works on the linux, but when i need to check on remote (windows) it doesn't work.
Is that because it's a windows platform, or is it that theire is nog Nagios installed on, or does anyone have an idea what the easiest way is to check those files on the remote server?
thx
grtz
rdedon
Re: Nagios/Centreon
Post by rdedon »
Hello Brownie,
a few quick questions:
-What Linux distro are you running and is it a VM?
-What version of Nagios are you running (Nagios Core, Nagios XI or other?)
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
