Re: [Nagios-devel] Nagios 3 Performance Monitoring
This is a cryptographically signed message in MIME format.
--------------ms020407010405050806070807
Content-Type: text/plain; charset=ISO-8859-15
Hi Andreas,
thanks for your answer.
Andreas Ericsson schrieb:
> Are you using embedded perl? If so, turn that off.
Ooops. I followed your thread about ePN but was surprised that I didn't
switch it off.
It's done now.
>> After the beginnings of the latency the graph seems to see no end. It
>> goes up to 700 seconds for my fifth instance, I guess it will increase
>> if I hadn't restartet the nagios process.
> Run it for just one instance. If you're debugging something, it doesn't
> make sense to run it on a resource-starved system.
Of course you're right, after stopping the first three instances latency
of five went down and throughput of host/service checks went up immediately.
But it doesn't explain exactly why the performance goes down after hours
of running time, does it?
IMHO, performance issues are ok shortly after startup until all things
are organized internally, but why should s.th. work for hours and then
breaks down? (I know, this question is like philosophy)
>> My idea is, that after a while the data structure for stats reaches a
>> amount that will take too much time for update and therefor the
>> execution time increases.
> In C, data structures are constant size, so it's a bit unclear what you
> mean by this.
I'm not a C professional... but after reviewing the stats code in
utils.c I'm sure: That looks safe.
To whom it may concern:
The struct check_stats only safes the check statistics for 11 different
check types for the last 15 elements (updated only every minute) to
genereate 1/5/15 minute check statistics.
Until a new idea I wait until tomorrow what the disabling of ePN will do
with my graphs.
Regards,
Hendrik
Content-Type: application/x-pkcs7-signature; name="smime.p7s"
Content-Disposition: attachment; filename="smime.p7s"
Content-Description: S/MIME Cryptographic Signature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...[email truncated]...
