Re: [Nagios-devel] Nagios2JSON
--------------010404060107090709020700
Content-Type: text/plain; charset=ISO-8859-1
Hash: SHA1
On 15/06/08 12:52 PM, Thomas Guyot-Sionnest wrote:
> On 14/06/08 11:16 PM, Yann JOUANIN wrote:
>> I finished coding the XSDJSON backend for Nagios, it works on Nagios 2 (I'm
>> finishing the Nagios3 version).
>> Now by enabling USE_XSDJSON, the file status.dat is formatted in JSON format
>> and the CGI are reading status from this format.
>> For the ones who want to test it, file are available on :
>> http://nagios2json.svn.sourceforge.net/ ... trunk/NAGI
>> OS2/
> Awesome work!
> I made it as a single patch for 2.x-cvs which also includes configure.in
> modifications.
> After applying the patch, be sure to run "autoconf" then you can
> configure Nagios with JSON routines with:
> ./configure --enable-xsdjson
> Configure will print the following near the end:
> We'll use JSON routines (in xdata/xsdjson.*) for status data I/O...
> Then usual make and make install to get everything installed.
> I haven't tested it yet (lack of time) but it does build successfully
> with JSON routines.
> Enjoy :)
As Yann pointed to in private my patch does not set USE_XSDJSON 1 in
config.h. Being used to have autoheader to write config.h.in for me I
forgot to update this one, and didn't realized the define was missing
(the code was built but not used).
This new patch fix this and should work properly. I also verified the
proper function are present in the object files (still no time to test,
unfortunately).
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFIWx9Q6dZ+Kt5BchYRAp7yAJ4qN0mgr20zrh74f4MZYDRQnhQvNgCg4Nmi
Jxea0hpbrGIhHxsNPe6ME2o=
=dSlN
-----END PGP SIGNATURE-----
Content-Type: text/x-diff;
name="nagios2.JSON_Status-beta1-2.patch"
Content-Disposition: inline;
filename="nagios2.JSON_Status-beta1-2.patch"
diff -uNr nagios.orig/common/statusdata.c nagios/common/statusdata.c
--- nagios.orig/common/statusdata.c 2008-06-19 22:26:29.000000000 -0400
+++ nagios/common/statusdata.c 2008-06-19 22:22:55.000000000 -0400
@@ -3,7 +3,7 @@
* STATUSDATA.C - External status data for Nagios CGIs
* Copyright (c) 2000-2005 Ethan Galstad ([email protected])
- * Last Modified: 07-25-2005
+ * Last Modified: 06-19-2008
* License:
@@ -43,6 +43,10 @@
#include "../xdata/xsddefault.h" /* default routines */
#endif
+#ifdef USE_XSDJSON
+#include "../xdata/xsdjson.h" /* JSON routines */
+#endif
#ifdef NSCORE
extern int aggregate_status_updates;
@@ -75,6 +79,10 @@
result=xsddefault_initialize_status_data(config_file);
#endif
+#ifdef USE_XSDJSON
+ result=xsdjson_initialize_status_data(config_file);
+#endif
return result;
@@ -93,6 +101,10 @@
result=xsddefault_save_status_data();
#endif
+#ifdef USE_XSDJSON
+ result=xsdjson_save_status_data();
+#endif
#ifdef USE_EVENT_BROKER
/* send data to event broker */
broker_aggregated_status_data(NEBTYPE_AGGREGATEDSTATUS_ENDDUMP,NEBFLAG_NONE,NEBATTR_NONE,NULL);
@@ -114,6 +126,10 @@
result=xsddefault_cleanup_status_data(config_file,delete_status_data);
#endif
+#ifdef USE_XSDJSON
+ result=xsdjson_cleanup_status_data(config_file,delete_status_data);
+#endif
return result;
@@ -198,10 +214,15 @@
#ifdef USE_XSDDEFAULT
result=xsddefault_read_status_data(config_file,options);
#endif
#ifdef USE_XSDDB
result=xsddb_read_status_data(config_file,options);
#endif
+#ifdef USE_XSDJSON
+ result=xsdjson_read_status_data(config_file,options);
+#endif
return result;
diff -uNr nagios.orig/configure.in nagios/configure.in
--- nagios.orig/configure.in 2008-06-19 22:26:29.000000000 -0400
+++ nagios/configure.in 2008-06-15 12:45:48.000000000 -0400
@@ -219,11 +219,24 @@
USE_PGSQL=no
dnl Status data
-AC_DEFINE_UNQUOTED(USE_XSDDEFAULT)
-XSDC="xsddefault.c"
-XSDH="xsddefault.h"
-XSDCOMMENT="Default (text f
...[email truncated]...
