Il s'agit d'un message à parties multiples au format MIME.
------=_NextPart_000_0016_01C993B5.221401F0
Content-Type: text/plain;
charset="iso-8859-1"
I also tried to write directly files to /var/spool/checkresults and I am
quite sure it improve performance a lot.
=20
Yann Jouanin
=20
http://www.yannj.fr
=20
De : Paul Fitzpatrick [mailto:[email protected]]=20
Envoy=E9 : vendredi 20 f=E9vrier 2009 00:05
=C0 : Nagios Developers List
Objet : Re: [Nagios-devel] High latencies problem.
=20
I am also using the command pipe to submit passive service checks via =
nsca
to a master nagios host which does notifications and runs event =
handlers.
I am also interested in knowing what is the alternative to the command =
pipe
referred-to by Daniel.
On Thu, Feb 19, 2009 at 1:51 AM, wrote:
Could someone light me about how to use something else than command pipe =
to
improve performance?
On Tue, 17 Feb 2009 08:32:32 -0800, "D. Emmanuel Feinsmith"
wrote:
> Alessandro,
Its inefficiency primarily arises when it needs to either
> receive passive checks (through the command pipe bottleneck)
> The key to nagios scalability and latency reduction is to educe the #
> of fork/exec's to the smallest amount possible and keep away from the
> command pipe as much as you can if you are passive-check heavy.
> Daniel.
Open Source Business Conference (OSBC), March 24-25, 2009, San =
Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the =
Enterprise
-Strategies to boost innovation and cut costs with open source =
participation
-Receive a $600 discount off the registration fee with the source code: =
SFAD
http://p.sf.net/sfu/XcvMzF8H
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
=20
Content-Type: text/html;
I also tried to write directly files to =
and I am quite sure it improve performance a lot.
<o:
...[email truncated]...
