Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
Hey folks,
One of my pet peeves when installing a new Nagios server is that
the check commands in checkcommands.cfg-sample are seemingly in
random order. I typically end up adding a lot of my own commands,
so the first thing I do is alphabetize them.
This diff puts the sample config file into alphabetical order,
no other changes. It just makes things a bit cleaner, IMHO.
Um, this diff is against the latest stable (2.0b6), so if it's
already been done in CVS, just ignore.
Benny
"NOT WORK SAFE! Extreme animated violence, language,
birds, and what appears to be God with a katana." -- SA list
------=_20051215173723_23327
Content-Type: application/octet-stream; name="checkcommands.diff"
Content-Disposition: attachment; filename="checkcommands.diff"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...[email truncated]...
