Content-Type: text/plain; charset=ISO-8859-1
This is for the circular host check. I use bit 1->5 of
host->is_being_freshened. I'm doing now the hostgroup's service patch.
Jean
On Thu, May 14, 2009 at 4:34 PM, nap wrote:
> On Thu, May 14, 2009 at 4:06 PM, Andreas Ericsson wrote:
>> nap wrote:
>>> Hi,
>>> If it's the patchs's day, I repost some of my patch proposal:
>>> Circular-parent2.patch : change the host circular check algorithm (no
>>> cycle in parents) by a Deep First Search based one. It really speed up
>>> the circular check and provide the same output as the old one, so can
>>> be apply without problem.
>> I really like this one, although with the current implementation, it
>> can't be applied without breaking the ABI for eventbroker modules,
>> which we're definitely loathe to do.
>> However, hosts have plenty of un-used bits in many of the integral
>> variables used as boolean flags. If you could rewrite the patch so
>> that one of those fields is used instead, I'd take this patch and
>> put it through the wringer without hesitation.
>>> Changepriority_service_on_hostgroup.patch : change the order of
>>> services in skiplist so services apply on host come before service
>>> apply on hostgroups. So When a service is apply in a host, it will be
>>> take even if a other service have been apply on a hostgroup where the
>>> host is. It can be use to override definition. It changes the
>>> behaviour of configuration but still raise warnings in the
>>> configuration check.
>> This patch has the same problem as the afore-mentioned one, in that
>> it changes the size of the service objects and thus breaks the
>> ABI. The same holds true here though; There are plenty of un-used
>> bits in the integral boolean flags that can be utilized instead.
>> For both the two patches mentioned above, one extra pass over all
>> objects has to be done to clear the bitflags once they're set.
>> I'd much prefer if you were to create small helper functions for
>> these routines, like so:
>> void dfs_set_host_unchecked(struct host_object *hst)
>> =A0 =A0hst->notify_on_errors &=3D 1;
>> int dfs_host_is_checked(struct host_object *hst)
>> =A0 =A0return hst->notify_on_errors & (1 > }
>> void dfs_set_host_checked(struct host_object *hst)
>> =A0 =A0hst->notify_on_errors |=3D (1 > }
>> I'm sure you get the idea. Care to amend the patches in such a way?
> Ok, I'm on it
>>> Ndo14b7_ssl_patch_v2 : user can use SSL connexion between ndomod and
>>> ndo2db. The option use_ssl is add in ndomod.cfg and ndo2db.cfg. If
>>> omitted, the SSL is used by default. The patch is not fully completed
>>> because the autoconf part is not finish (I took the code from NRPE). I
>>> never take thetime to, so if someone want to finish this part...
>> I won't comment on this since I know very little about NDOUtils.
>>> Gab=E8s Jean
>> Is Gab=E8s your first name or your surname? I need to know to get the
>> attribution correct for when I apply the patches.
> last name : Gab=E8s
> first name : Jean
>> Thanks.
> Gab=E8s Jean
>> Andreas Ericsson =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 andreas.ericsson@op=
5.se
>> OP5 AB =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 www.op5.s=
e
>> Tel: +46 8-230225 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0Fax: +46 8-230231
>> Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
>> =A0http://nordicmeetonnagios.op5.org/
>> Considering the successes of the wars on alcohol, poverty, drugs and
>> terror, I think we should give some serious thought to declaring war
>> on peace.
>> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
>> production scanning environment may not be a perfect world - but thanks =
to
>> Kodak, there's a perfect scanner to get the job done! With the NEW KOD
...[email truncated]...
