[Nagios-devel] New plugin for checking Cacti (rrd databases)
------=_NextPart_000_00B0_01C96CEB.AD634BD0
Content-Type: text/plain;
charset="us-ascii"
Because of my work I had to write a little PHP script to integrate
with Nagios. It works checking local RRD databases (Nagios and Cacti on same
computer for example) for incoming or outgoing transfer rates.
I think that this script can be useful to others, so I want to known if it
can be enhanced / corrected to be included in a future release.
The script, a configuration command file definition, and a demo host are
attached to this e-mail.
Saludos. Pablo.
Pd> Sorry for my bad English.
Pd2>
---------------------- help output ------------------------------------
$ check_rrdtraf.php -h
This plugin will check the incoming/outgoing transfer rates of a router,
switch, etc recorded in an Cacti rrd database
By Pablo Armando (c) 2009
Usage:
check_rrdtraf [-h] -f rrd_file -I|-O -w min_warning -W max_warning
-c min_critial -C max_critical
Example:
check_rrdtraf -f /var/lib/cacti/rra/mx_1_traffic_in_239.rrd -w 1000
-W 2000 -c 4000 -C 4500 -I
This checks if the input traffic (-I) is between 1000 and 2000kbps.
If this is true a warning message will be fired. If the input traffic
is between 4000 and 4500kbps then a critic message will be fired
-h Show this help
-f full path to rrd database
-I check input traffic from incoming data source
-O check output trafic from outgoing data source
-w start of warning range - Required
-W end of warning range - Required
-c start of critic range - Required
-C end of critic range - Required
The values for -w, -W, -c, and -C are expresed in kbps
Content-Type: application/octet-stream;
name="rrdtraf-v0-1.tar.gz"
filename="rrdtraf-v0-1.tar.gz"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...[email truncated]...
