[Nagios-devel] [BUGFIX] cmd.c: Forced re-scheduling of single
Hi List,
since 3.0.5 the "Force Check" checkbox is ignored when service checks
are to be rescheduled from the web-ui. The resulting command is always
SCHEDULE_SVC_CHECK instead of SCHEDULE_FORCED_SVC_CHECK because the
value of the checkbox (stored in force_check) is never interpreted.
This is only for the case for single service checks. Host checks and
"all service checks for a particular host" work as expected.
Matthias
--- nagios-3.0.6.old/cgi/cmd.c 2008-11-30 18:22:58.000000000 +0100
+++ nagios-3.0.6/cgi/cmd.c 2008-12-09 11:22:27.423898000 +0100
@@ -2033,7 +2033,8 @@
break;
case CMD_SCHEDULE_SVC_CHECK:
- case CMD_SCHEDULE_FORCED_SVC_CHECK:
+ if (force_check == TRUE)
+ cmd = CMD_SCHEDULE_FORCED_SVC_CHECK;
result = cmd_submitf(cmd,"%s;%s;%
lu",host_name,service_desc,start_time);
break;
