Re: [Nagios-devel] Nagios 2.2 internal server error.
--------------090107010806030000030104
Hello Eli,
the problem is totally random and it does't happen in the 15 plus
servers a have running 2.0b4, only since nagios 2.0 final this started
to happen.
I am running in on Fedora Core 3, x86, GCC specs, Thread model:
posix gcc version 3.4.4 20050721 (Red Hat 3.4.4-2).
[]s.
Eli Stair wrote:
> Yes, and haven't resolved it or tracked down the cause yet. Always
> the CGI's segfaulting randomly. Mine started in b4 also (IIRC),
> though perhaps it was b2... I've got some unresolved posts in the
> archives. There are some well-documented causes/fixes for this, none
> of which were my issue. If you haven't already, you might want to
> check the archives/google/FAQ.
> What is your arch and compiler? Does it recur in the same scenario,
> is it repeatable, or random?
> /eli
> Alessandro Ren wrote:
>> Helllo,
>> I've some servers running nagios, one is running nagios 2.2 and in
>> this server, a get a internal server error from time to time in the
>> status.cgi while it is refreshing.
>> In the others, that run nagios 2.0b4, this naver happened.
>> I wonder if someone is having the same problem?
>> Thanks.
>> __________________________________________________
>> *Alessandro Ren*
>> /*OpServices*/
>> /*Luciana de Abreu, 471 - Sala 403*/
>> /*Porto Alegre, RS - CEP 90570-060*/
>> *(* phone 55(51)3061-3588
>> *4* fax 55(51)3061-3588
>> *Q* mobile 55(51)8151-8212
>> *:* email [email protected]
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job
> easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache
> Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
*Alessandro Ren*
/*OpServices*/
Content-Type: text/html; charset=ISO-8859-1
    Hello Eli,
to happen.
    []s.
Eli Stair wrote:
Yes, and haven't resolved it or tracked down the cause yet.  Always the
CGI's segfaulting randomly.  Mine started in b4 also (IIRC), though
perhaps it was b2... I've got some unresolved posts in the archives.
There are some well-documented causes/fixes for this, none of which
were my issue.  If you haven't already, you might want to check the
What is your arch and compiler?  Does it recur in the same scenario, is
/eli
    H
...[email truncated]...
