My thoughts exactly, but I was thinking of doing something like or
integrating my work with, whatever works best, DNX. At which point it
would become a little harder to do without a module.
Sure you could still do it but it would get harder. After all the
command file is one way only and though you can put a lot in the
active check command it might not be the best way. Still all that is
for way later. In fact I think more likely that it will be something
that sits next to DNX (when it gets worker node affinity in place). No
sense in re-inventing the wheel if there is a good working solution
available.
Cheers,
Hans
On Tue, Nov 4, 2008 at 9:37 PM, Andreas Ericsson wrote:
> The nagios command file has very little overhead associated with it.
> You will almost definitely not need to write a module for that reason.
