Hi, after a succeful compilation of nagios in Linux RedHat 7.x,
I tried with Tru 64 Unix V5.1. The compiler seems more
rigurous (and correct):
BTW, I'm using nagios-1.0b6 source (downloaded last week, not CVS)
1)../common/downtime.c:
cc: Warning: ../common/downtime.c, line 669: The scalar variable "result" is
fetched but not initialized. And there may be other such fetches of this
variable that have not been reported in this compilation. (uninit1)
return result;
Solution: CHANGED "return result" for "return 0".
2)
cc: Warning: ../xdata/xodtemplate.c, line 2798: The scalar variable
"host_name" is fetched but not initialized. And there may be other such
fetches of this variable that have not been reported in this compilation.
(uninit1)
free(host_name);
Solution: COMMENT the free invocation.
3)
cc: Warning: ../xdata/xodtemplate.c, line 2742: The scalar variable
(uninit1)
free(host_name);
Solution: SAME as ABOVE
4)
cc: Warning: ../xdata/xodtemplate.c, line 5826: In this statement, the
number of conversion specifiers to snprintf exceeds the number of values to
be converted. Conversion specifiers from "%d" onward will process
meaningless and perhaps invalid data. (outtoofew)
snprintf(temp_buffer,sizeof(temp_buffer)-1,"Error:
Could not add contactgroup '%s' to hostgroup escalation (config file '%s',
line
%d)\n",xodtemplate_config_file_name(this_hostgroupescalation->_config_file),this_hostgroupescalation->_start_line);
Solution: Changed the '%s' parameter corresponding to "contact
group" to some plain text.
5)
cc: Error: nagios.c, line 296: In the initializer for long_options, an
array's element type is incomplete, which precludes its initialization.
(incompelinit)
{"help",no_argument,0,'h'},
Solution: It seems that Tru64 compiler uses the HAVE_GETOPT_H
preprocessor definition but actually dosen't defines the
gnu getopt long functions. So I added a:
#undef HAVE_GETOPT_H
at line 49 (before it is used). This was enough.
I didn't tried yet the resulting files.
Diego Bravo Estrada
_________________________________________________________________
Únase al mayor servicio mundial de correo electrónico:
http://www.hotmail.com/es
