[Nagios-devel] Hide services that are checked with check_cluster2
------=_Part_1076_10816474.1189759548068
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
I'm just wondering if there some way to hide services that have
notifications disabled in the webgui? The reason is that I use
check_cluster2 and monitor the same service on two hosts and since it's a
master/slave setup it will only run on one node at any given time. This
works OK, check_cluster2 sends notifications if the service is not running
on any node, But this messes up my tactical and my problem->service view,
with services I have know is down.
So is there a way of "hiding" these services somehow?
BR
Robert Lindgren
Content-Type: text/html; charset=ISO-8859-1
Hi,I'm just wondering if there some way to hide services that have notifications disabled in the webgui? The reason is that I use check_cluster2 and monitor the same service on two hosts and since it's a master/slave setup it will only run on one node at any given time. This works OK, check_cluster2 sends notifications if the service is not running on any node, But this messes up my tactical and my problem->service view, with services I have know is down.
So is there a way of "hiding" these services somehow?BRRobert Lindgren
------=_Part_1076_10816474.1189759548068--
