[Nagios-devel] Still problems with Nagios 2.9 and NDO under Solaris
------_=_NextPart_001_01C7F5E4.2EE1F1FA
Content-Type: text/plain;
charset="iso-8859-1"
Hi all,
=20
i'm still having problems with ndoutils under Solaris 9.
=20
When i'm activating it (event_broker_options=3D-1) in nagios.cfg
my nagios won't start anymore !! it always stops with a segmentation =
fault!
=20
here's the traceback of the dump:
=20
(gdb) bt
#0 0xff1b3288 in strlen () from /usr/lib/libc.so.1
#1 0xff10bcbc in ndo_escape_buffer (buffer=3DCannot access memory at =
address 0x44
) at io.c:424
#2 0xff104788 in ndomod_write_object_config (config_type=3D1) at =
ndomod.c:3183
#3 0xff103d30 in ndomod_write_config (config_type=3D1) at ndomod.c:2999
#4 0xff103b44 in ndomod_broker_data (event_type=3D7, data=3D0xffbef954) =
at ndomod.c:2940
#5 0x0001d038 in neb_make_callbacks ()
#6 0x0001ca38 in broker_program_state ()
#7 0x0001b67c in main ()
is there anyone who could shed a little lite on this ??
=20
thanks a lot,
christian
Content-Type: text/html;
Hi=20
all,
i'm =
still having=20
When =
i'm activating=20
my =
nagios won't=20
start anymore !!   it always stops with a segmentation=20
fault!
here's =
the traceback=20
of the dump:
(gdb) =
bt#0 =20
0xff1b3288 in strlen () from /usr/lib/libc.so.1#1  0xff10bcbc =
in=20
ndo_escape_buffer (buffer=3DCannot access memory at address 0x44) at =
io.c:424#2  0xff104788 in ndomod_write_object_config =
(config_type=3D1) at=20
ndomod.c:3183#3  0xff103d30 in ndomod_write_config =
ndomod.c:2999#4  0xff103b44 in ndomod_broker_data =
(event_type=3D7,=20
data=3D0xffbef954) at ndomod.c:2940#5  0x0001d038 in =
neb_make_callbacks=20
()#6  0x0001ca38 in broker_program_state ()#7  =
0x0001b67c in=20
main ()
is =
there anyone who=20
thanks =
a=20
lot,
christian
------_=_NextPart_001_01C7F5E4.2EE1F1FA--
