Re: [Nagios-devel] re patch for nrpe.c : stderr output causes CRC error
Simon Kitching writes:
> Hi Ethan,
> I see you've applied both my patches - thanks.
> There seems to be a glitch with this one, though:
> [line 235, nrpe.c]
> /* redirect STDERR to /dev/null
> close(2);
> open("/dev/null",O_WRONLY);
> Note the missing close-of-comment, which turns all the above lines into
> comments.
Simon, could I mention that that isn't very good code?
In particular, if something does
close(0);
and then exec()'s your program, things won't
behave as you expect.
Much safer to do
int fd;
fd = open("/dev/null", O_WRONLY);
if (fd != 2) {
dup2(fd, 2);
close(fd);
(the dup2() will do a close on stderr first if needed).
